can a SD card be used as storage with emmc boot
hello
booting from emmc
so SD slot not used
but
can i use it for storage?
used lsblk, with a SD card inserted [format: ntfs-3], showed up as /dev/mmcblk1 [emmc was /dev/mmcblk0]
but mount failed, [tried a few different options]
also edited fstab, /dev/mmcblk /mnt/SD/ ntfs-3 auto rw 0 0
but the rock tried to boot from SD, which was empty, [had to remove above line from fstab]
can you please advise want to do
thanks
actually used an usb stick which automounted fine [mounted as /dev/sda]
can a SD card be used as storage with emmc boot - by Enzo - 04-27-2018, 08:53 AM
Question Compatible eMMC modules and benchmarks danboid 7 21,290 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 3,921 08-28-2021, 04:53 AM
Last Post: CounterPillow
  RS-485 CAN HAT Rock won’t boot gnvdude 1 4,357 01-10-2021, 05:15 PM
Last Post: as365n4
  Help! Rock64 won't boot anything! trohn_javolta 3 8,975 03-09-2020, 06:03 PM
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 9,520 05-04-2019, 04:19 AM
Last Post: burito111
  Boot from M.2/USB 3 Max_H 8 14,628 05-03-2019, 02:56 AM
Last Post: Monstercrunch
  emmc module help default_user8 1 4,195 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Boot on power-up vicencb 1 4,118 11-26-2018, 11:45 PM
Last Post: evilbunny
  Dead eMMC? machina 8 13,189 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 7,363 11-12-2018, 03:34 PM
Last Post: Tortax
