suggested config for C++ programming
Sure Eclipse works on the Rock64 and similar SBCs, but it's not quite the experience you  get using it on Windows or MAC.  If you've ever used NotePad++ on Windows, you might want to try BlueFish!  BlueFish is far from a complete environment, but it's great for working in, if you like a more basic environment!
suggested config for C++ programming - by pas059 - 04-23-2018, 11:54 AM
RE: suggested config for programming - by pas059 - 05-03-2018, 03:43 AM
RE: suggested config for programming - by tllim - 05-03-2018, 09:43 PM
RE: suggested config for programming - by pas059 - 05-04-2018, 03:02 AM
RE: suggested config for programming - by KeithJohnAlger - 05-06-2018, 01:50 AM
RE: suggested config for programming - by pas059 - 05-07-2018, 03:39 AM
RE: suggested config for programming - by pas059 - 07-05-2018, 02:22 AM
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 2,104 09-09-2019, 09:39 AM
Last Post: shivarj89
  Enable I2C, I2s, SPI in boot-config file? HelgeMK 3 8,743 08-14-2018, 10:59 AM
Last Post: pas059
