GPIO extension cable fault
Sorry for the long time since last reply!
well... I can confirm two things now:
1) this issue is caused by something connected on GPIOs mentioned by pfeerick (from32 to 40 in PI-2) (thanks for the advice!!)
2) this exists only if running from SD, if running from eMMC I may connect everything on all GPIO without problem!
thanks to all for the precious support!!
Viguzzz
GPIO extension cable fault - by viguzzz - 04-23-2018, 04:08 AM
RE: GPIO extension cable fault - by viguzzz - 05-03-2018, 03:49 AM
RE: GPIO extension cable fault - by pfeerick - 05-03-2018, 03:53 PM
RE: GPIO extension cable fault - by viguzzz - 05-04-2018, 01:18 AM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 02:48 PM
RE: GPIO extension cable fault - by pfeerick - 05-04-2018, 05:42 PM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 09:13 PM
RE: GPIO extension cable fault - by viguzzz - 05-05-2018, 02:45 AM
RE: GPIO extension cable fault - by Rocklobster - 05-05-2018, 05:38 AM
RE: GPIO extension cable fault - by pfeerick - 05-05-2018, 08:19 PM
RE: GPIO extension cable fault - by viguzzz - 05-17-2018, 08:04 AM
RE: GPIO extension cable fault - by pfeerick - 05-18-2018, 03:45 AM
RE: GPIO extension cable fault - by viguzzz - 05-18-2018, 04:03 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,154 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 10,631 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,019 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 6,878 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 2,968 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 3,475 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 8,978 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 9,914 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 14,826 12-02-2017, 03:44 AM
Last Post: xalius
