GPIO extension cable fault
(05-05-2018, 05:38 AM)Rocklobster Wrote: I assume GPIO is correctly configured at boot time. I do recall a blob file that could be used in the Raspberry Pi board to configure GPIO and a firmware configuration that could be called from sudo raspi-config but I'm not sure how it's handled with the Rock64.
Think the GPIO stuff is handled by overlays, borrowed from the Raspberry Pi. Prior to 0.6.27, I'm pretty sure the GPIOs were all enabled for simple input/output stuff via sysfs.
Rocklobsters single wire connectors suggestion is good... you can get them easily on places like eBay, Aliexpress and Amazon really cheaply... good search keywords are "dupont breadboard"... as they are dupont style connectors and commonly used on prototyping breadboards.
i.e. https://www.ebay.com/itm/40X-Breadboard-...3115552438 where you can choose the length and connector type... the male to female type mean you don't even need the adapter plate to connect to breadboard. It's always handy to have a set of each combination if you're actively doing stuff on breadboards... they always come in handy! Wink
GPIO extension cable fault - by viguzzz - 04-23-2018, 04:08 AM
RE: GPIO extension cable fault - by viguzzz - 05-03-2018, 03:49 AM
RE: GPIO extension cable fault - by pfeerick - 05-03-2018, 03:53 PM
RE: GPIO extension cable fault - by viguzzz - 05-04-2018, 01:18 AM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 02:48 PM
RE: GPIO extension cable fault - by pfeerick - 05-04-2018, 05:42 PM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 09:13 PM
RE: GPIO extension cable fault - by viguzzz - 05-05-2018, 02:45 AM
RE: GPIO extension cable fault - by Rocklobster - 05-05-2018, 05:38 AM
RE: GPIO extension cable fault - by pfeerick - 05-05-2018, 08:19 PM
RE: GPIO extension cable fault - by viguzzz - 05-17-2018, 08:04 AM
RE: GPIO extension cable fault - by pfeerick - 05-18-2018, 03:45 AM
RE: GPIO extension cable fault - by viguzzz - 05-18-2018, 04:03 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,200 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 10,651 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,028 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 6,897 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 3,478 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 8,994 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 9,927 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 14,849 12-02-2017, 03:44 AM
Last Post: xalius
