GPIO extension cable fault
(05-04-2018, 02:48 PM)Rocklobster Wrote: Sounds suspiciously like a short in the actual connector going to the GPIO pins. If you haven't connected the other end to a breadboard all you doing is extending the actual GPIO pins so any reading should be the same with or without the ribbon cable connector at the Rock64 board. Try a different cable just to rule it out.
Have you tested voltages at the GPIO pins with and without the ribbon cable attached.
I'm getting the same results on my setup. https://pastebin.com/JXg8mCc4 The only (!!) difference is I plugged in the adapter plate to the ribbon as I needed to be able to disable the SPI Flash as there is a bug in the uboot currently loaded on it.
I think it can only be one of three things... something connected/shorted on the adapter board,  something going on in the ribbon, or it could perhaps be adding noise or capacitance or something to the lines used for the SD card, as the pins 32.32,35,36,37,38,40 on the 40 pin Pi-2 bus are shared with the SD card. I'm inclined to think the latter, as there is nothing visibly wrong with the adapter or ribbon.
GPIO extension cable fault - by viguzzz - 04-23-2018, 04:08 AM
RE: GPIO extension cable fault - by viguzzz - 05-03-2018, 03:49 AM
RE: GPIO extension cable fault - by pfeerick - 05-03-2018, 03:53 PM
RE: GPIO extension cable fault - by viguzzz - 05-04-2018, 01:18 AM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 02:48 PM
RE: GPIO extension cable fault - by pfeerick - 05-04-2018, 05:42 PM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 09:13 PM
RE: GPIO extension cable fault - by viguzzz - 05-05-2018, 02:45 AM
RE: GPIO extension cable fault - by Rocklobster - 05-05-2018, 05:38 AM
RE: GPIO extension cable fault - by pfeerick - 05-05-2018, 08:19 PM
RE: GPIO extension cable fault - by viguzzz - 05-17-2018, 08:04 AM
RE: GPIO extension cable fault - by pfeerick - 05-18-2018, 03:45 AM
RE: GPIO extension cable fault - by viguzzz - 05-18-2018, 04:03 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,200 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 10,651 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,028 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 6,897 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 3,478 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 8,994 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 9,927 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 14,849 12-02-2017, 03:44 AM
Last Post: xalius
