GPIO extension cable fault
Sounds suspiciously like a short in the actual connector going to the GPIO pins. If you haven't connected the other end to a breadboard all you doing is extending the actual GPIO pins so any reading should be the same with or without the ribbon cable connector at the Rock64 board. Try a different cable just to rule it out.
Have you tested voltages at the GPIO pins with and without the ribbon cable attached.
GPIO extension cable fault - by viguzzz - 04-23-2018, 04:08 AM
RE: GPIO extension cable fault - by viguzzz - 05-03-2018, 03:49 AM
RE: GPIO extension cable fault - by pfeerick - 05-03-2018, 03:53 PM
RE: GPIO extension cable fault - by viguzzz - 05-04-2018, 01:18 AM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 02:48 PM
RE: GPIO extension cable fault - by pfeerick - 05-04-2018, 05:42 PM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 09:13 PM
RE: GPIO extension cable fault - by viguzzz - 05-05-2018, 02:45 AM
RE: GPIO extension cable fault - by Rocklobster - 05-05-2018, 05:38 AM
RE: GPIO extension cable fault - by pfeerick - 05-05-2018, 08:19 PM
RE: GPIO extension cable fault - by viguzzz - 05-17-2018, 08:04 AM
RE: GPIO extension cable fault - by pfeerick - 05-18-2018, 03:45 AM
RE: GPIO extension cable fault - by viguzzz - 05-18-2018, 04:03 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,200 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 10,651 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,028 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 6,897 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 2,974 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 3,478 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 8,994 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 9,927 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 14,849 12-02-2017, 03:44 AM
Last Post: xalius
