GPIO extension cable fault
Hi Everybody!
I' received few time ago a Rock64 2G I'll like o use as media server
I'm also trying to connect GPIO to a prototyping board through a ribbon cable 28AWG 40wires (similar to the ones once used for ATA disk) but as soon as I try to connect this cable I have loads of error
Apr 23 09:19:55 rock64 kernel: [   68.768983] mmcblk1: error -84 transferring data, sector 1723920, nr 32, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   68.784147] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.817032] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.818136] mmc1: tried to reset card
Apr 23 09:19:55 rock64 kernel: [   68.819089] mmcblk1: error -5 transferring data, sector 1723920, nr 32, cmd response 0x900, card status 0xb00
Apr 23 09:19:55 rock64 kernel: [   68.820177] mmcblk1: retrying using single block read
Apr 23 09:19:55 rock64 kernel: [   68.821655] mmcblk1: error -84 transferring data, sector 1723921, nr 31, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   68.837149] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.870031] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.871150] mmc1: tried to reset card
Apr 23 09:19:55 rock64 kernel: [   68.874435] mmcblk1: error -110 sending status command, retrying
Apr 23 09:19:55 rock64 kernel: [   68.875149] mmcblk1: error -84 transferring data, sector 1723927, nr 25, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   68.891146] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.924033] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.925152] mmc1: tried to reset card
Apr 23 09:19:55 rock64 kernel: [   68.928530] mmcblk1: error -110 sending status command, retrying
Apr 23 09:19:55 rock64 kernel: [   68.929225] mmcblk1: error -84 transferring data, sector 1723935, nr 17, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   68.945150] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.978031] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   68.979163] mmc1: tried to reset card
Apr 23 09:19:55 rock64 kernel: [   68.980039] mmcblk1: error -84 transferring data, sector 1723935, nr 17, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   68.981151] blk_update_request: I/O error, dev mmcblk1, sector 1723935
Apr 23 09:19:55 rock64 kernel: [   68.990404] mmcblk1: error -5 transferring data, sector 1723920, nr 8, cmd response 0x900, card status 0x0
Apr 23 09:19:55 rock64 kernel: [   69.006146] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   69.039027] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Apr 23 09:19:55 rock64 kernel: [   69.040152] mmc1: tried to reset card
the wired thing is that nothing is connected on the other side of ribbon cable when I get this error....
Thanks for any help or advice
GPIO extension cable fault - by viguzzz - 04-23-2018, 04:08 AM
RE: GPIO extension cable fault - by viguzzz - 05-03-2018, 03:49 AM
RE: GPIO extension cable fault - by pfeerick - 05-03-2018, 03:53 PM
RE: GPIO extension cable fault - by viguzzz - 05-04-2018, 01:18 AM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 02:48 PM
RE: GPIO extension cable fault - by pfeerick - 05-04-2018, 05:42 PM
RE: GPIO extension cable fault - by Rocklobster - 05-04-2018, 09:13 PM
RE: GPIO extension cable fault - by viguzzz - 05-05-2018, 02:45 AM
RE: GPIO extension cable fault - by Rocklobster - 05-05-2018, 05:38 AM
RE: GPIO extension cable fault - by pfeerick - 05-05-2018, 08:19 PM
RE: GPIO extension cable fault - by viguzzz - 05-17-2018, 08:04 AM
RE: GPIO extension cable fault - by pfeerick - 05-18-2018, 03:45 AM
RE: GPIO extension cable fault - by viguzzz - 05-18-2018, 04:03 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,154 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 10,631 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,019 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 6,878 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 2,968 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 3,475 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 8,978 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 9,914 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 14,826 12-02-2017, 03:44 AM
Last Post: xalius
