Rockpro64 with sata pcie card and omv
So just some wall power numbers here I have taken with my current PC (Fx-8350, R7 260x, 1x SSD, 8x HDD).
As a baseline, system in idle with all monitors switched off and all harddrives spun down is 90W wall power.
Spinning up the hard drives with staggered spinup adds roughly 20-30W during the spin up and roughly 7W per drive which has spun up (which really does not match what is printed on the hard drives). This is without transferring data though.
My plan is to basically outsource the 8x hard drives from my main computer to a dedicated nas which most of the time will be idle (so good idle power + stager down + maybe wake on lan would be good). So I obviously do not want more energy than my system is consuming at the moment.
While I know that it is always good to have spare room in the energy consumption department, if you run a 500W power supply only consuming 20W most of the time means you are running the power supply in a energy range it s not design to have good efficiency. On the other hand, many low power power supplies do not have good efficiencies to start with. So still really torn what to do.
At the moment, I think the easiest solution would be to have two of these: https://www.alternate.de/Phobya/Externes...ct/1290923
That would give me 140W peak but I am not sure how efficient these things actually are...
Alternatively, one could get the smallest be quiet ATX power supply which is like 300Ws and hopefully also has good efficiency at 20W-50W in idle...
Rockpro64 with sata pcie card and omv - by xtract - 04-21-2018, 06:51 AM
RE: Rockpro64 with sata pcie card and omv - by p91 - 05-05-2018, 03:55 PM
  Installing Wifi drive for the RockPro64 John45595 0 286 02-10-2024, 11:32 PM
Last Post: John45595
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 118,818 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 742 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 672 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,206 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 877 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,306 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,792 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,622 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,005 01-27-2023, 07:43 PM
Last Post: Spater
