Python GPIO Library for the Rock64 (R64.GPIO)
#31
I can run under Ubuntu, but can't run the test script under Armbian. Using python3 I get:
root@rock64:/home/sas# python3 gpio_test.py
Testing R64.GPIO Module...
Module Variables:
Name           Value
GPIO.ROCK      ROCK
GPIO.BOARD     BOARD
GPIO.BCM       BCM
GPIO.OUT       out
GPIO.IN        in
GPIO.HIGH      1
GPIO.LOW       0
GPIO.PUD_UP    0
GPIO.PUD_DOWN  1
GPIO.VERSION   0.6.3
GPIO.RPI_INFO  {'RAM': '1024M', 'PROCESSOR': 'BCM2837', 'TYPE': 'Pi 3 Model B', 'REVISION': 'a22082', 'P1_REVISION': 3, 'MANUFACTURER': 'Embest'}
Error: Unable to export GPIO
Error: Unable to set GPIO direction
Testing GPIO Input/Output:
You must setup() the GPIO channel ({0} {1}) first
Traceback (most recent call last):
  File "gpio_test.py", line 42, in <module>
    var_gpio_state = GPIO.input(var_gpio_out)                   # Return state of GPIO
  File "/home/sas/R64/_GPIO.py", line 210, in input
    if validate_direction(channel, 'both') == 0:
  File "/home/sas/R64/_GPIO.py", line 118, in validate_direction
    print("You must setup() the GPIO channel ({0} {1}) first").format(gpio_mode, channel)
AttributeError: 'NoneType' object has no attribute 'format'
RE: Python GPIO Library for the Rock64 (R64.GPIO) - by pantera - 11-20-2018, 01:55 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 113 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,448 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,863 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 254 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,770 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,790 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,396 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,973 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 905 10-07-2022, 07:50 PM
Last Post: rookie_267
