None of my Wifi modules work
(04-01-2018, 03:47 AM)pfeerick Wrote:
(03-31-2018, 06:43 PM)NicoD Wrote: files.pine64.org_xenial-mate-rock64-0.5.15-136-20180102-arm64-sd2emmc.img.xz
files.pine64.org_stretch-mate-rock64-0.5.15-136-20171222-arm64.img
There are newer 'testing' versions available @ https://github.com/ayufan-rock64/linux-build/releases (currently 0.6.29, which has just had more WiFi related stuff added, but I'm only up to 0.6.25 atm).
Thank you so much.
I installed the ubuntu-mate-desktop onto xenial-minimal-rock64-0.6.29-201-arm64.img.xz
It all works great. Wifi works, Blender works, surfing works. Youtube works only when screen resolution is 720p and also video quality no higher than 720p, but it works great.
There also is no screen tearing anymore.
So great job. This is a lot better than that image from the Pine64 Installer.
Another question.
Is there an easy way to overclock the Rock64? I've got an active cooler above the heatsink, when maxed out it doesn't go above 60°C, so some overlcocking would be nice.
It now is faster than the Rasp 3b+(even when it's overclocked to 1.57Ghz) in Blender, but against the Odroid C2 or Tinker Board it's no match at 1.3Ghz.
Thanks again, have a nice day.
NicoD
None of my Wifi modules work - by NicoD - 03-26-2018, 09:40 AM
RE: None of my Wifi modules work - by xalius - 03-26-2018, 12:54 PM
RE: None of my Wifi modules work - by NicoD - 03-31-2018, 06:43 PM
RE: None of my Wifi modules work - by pfeerick - 04-01-2018, 03:47 AM
RE: None of my Wifi modules work - by NicoD - 04-01-2018, 01:02 PM
RE: None of my Wifi modules work - by NicoD - 04-02-2018, 10:15 AM
RE: None of my Wifi modules work - by NicoD - 04-05-2018, 01:05 PM
RE: None of my Wifi modules work - by tllim - 04-05-2018, 02:53 PM
Question Compatible eMMC modules and benchmarks danboid 7 21,322 03-09-2023, 08:14 AM
Last Post: arvendui
  get wifi mt7601u mediatek usb dongle to work Johannes 0 4,165 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 14,889 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 31,849 05-13-2020, 05:03 PM
  low speed wifi pas059 4 7,746 05-13-2019, 12:09 PM
Last Post: pas059
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 2,608 05-03-2019, 01:32 AM
Last Post: pcosm
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 5,693 03-08-2019, 02:44 AM
Last Post: shripal17
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 2,591 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  50 kb with RTL8188eu WIFI adapter Juice4 2 5,208 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 4,017 11-01-2018, 12:21 AM
Last Post: wsk
