[Issue] All Rock leds are blinking
(03-23-2018, 11:26 AM)k0Lm_ Wrote:
(03-23-2018, 06:33 AM)Chispolas Wrote: Hi everyone,  I just bought a rock64 and my problem is that the leds (green, white and red) are always blinking...Someone can tell me whats happening? I have checked the input power, however I bought too the adapter with the rock64.
I have noticed when all is in silent, you can heard a noise, like a clock that sound the same time the leds are blinking.
I need some help... I don't know what I should do, because is the first time trying to connect the rock64 and doesn't work.
Question, have you inserted an MicroSD or using SD->eMMC with an eMMC card init loaded with an O/S image or such ?
If so, does it give a video output ?
Sinceresly, I don't believe the SD card is the problem. Anyway i have a MicroSD loaded with an Linux OS but If I don't insert the card and in the moment try to power on the board I get the same behaviour
[Issue] All Rock leds are blinking - by Chispolas - 03-23-2018, 06:33 AM
RE: [Issue] All Rock leds are blinking - by k0Lm_ - 03-23-2018, 11:26 AM
RE: [Issue] All Rock leds are blinking - by Chispolas - 03-24-2018, 06:06 AM
  Rock 64 failure / kernel panic n0021913 2 5,390 07-07-2022, 01:16 PM
Last Post: anchor00
Sad No boot, garbage console text and blinking red light ... jean_bruder 2 5,914 07-19-2020, 08:37 AM
Last Post: jean_bruder
  HDMI 2.0a CEC compliancy issue? Willem53 1 3,997 04-13-2019, 08:02 AM
Last Post: Willem53
  Rock 64 seem like a dead end munocat 3 7,356 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 4,678 03-12-2019, 09:35 AM
Last Post: georgegohl888
  self-reboot issue pas059 6 11,131 02-11-2019, 05:02 AM
Last Post: pas059
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,192 02-05-2019, 05:41 PM
Last Post: ictele
  Rock 64 a failure..very disappointed arxaios 5 10,235 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  My Rock64 no power or light issue Nolaboy406 3 6,720 07-24-2018, 12:52 AM
Last Post: Luke
  Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141 techyjtmb 9 16,060 06-23-2018, 09:52 AM
Last Post: NablaMetal
