Rock64 Starter Kit Help
My starter kit:
- ROCK64 MEDIA BOARD COMPUTER DRAM: 4GB (more RAM = better, especially if you copy large files)
- ROCK64 / PINE A64 / PINE H64 Heatsink (one is sufficient, could be a bigger one but heat is not the issue for Roch64)
- ROCK64 USB WIFI 802.11B/G/N (RTL8188EU) (works out of the box - good addition if you need simple wi-fi)
- ROCK64 ACRYLIC OPEN ENCLOSURE (could be better - there are other options on Amazon)
- ROCK64 / PINE H64 5V 3A INTERNATIONAL POWER SUPPLY with AU, EU, UK, US PLUG (!!must have!! as it looks as they pick the barrel that fits perfectly into your Rock's socket. I had 2 boards, swapped power supplies and the barrel was lose so I had power loses/disconnects)
- 64GB eMMC Module (size is not important if you use OVM)
- USB Adapter for eMMC Module (!!if you use eMMC it's a life saver!! makes installation easy peasy)
Rock64 Starter Kit Help - by chaust - 03-20-2018, 07:18 PM
RE: Rock64 Starter Kit Help - by mikedhoore - 03-21-2018, 10:25 AM
RE: Rock64 Starter Kit Help - by Luke - 03-21-2018, 10:57 AM
RE: Rock64 Starter Kit Help - by easyfab - 03-21-2018, 11:47 AM
RE: Rock64 Starter Kit Help - by Nelly - 03-21-2018, 01:41 PM
RE: Rock64 Starter Kit Help - by pfeerick - 03-21-2018, 09:24 PM
RE: Rock64 Starter Kit Help - by Luke - 03-22-2018, 03:13 AM
RE: Rock64 Starter Kit Help - by S3phi40T - 03-22-2018, 04:20 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 255 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,241 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,626 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,069 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 325 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,863 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,493 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,075 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 744 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 944 10-07-2022, 07:50 PM
Last Post: rookie_267
