android locked!!
(03-22-2018, 04:25 PM)Trash_Can_Man Wrote:
(03-21-2018, 03:47 AM)kyllo Wrote:
(03-20-2018, 09:33 PM)evilbunny Wrote:
(03-20-2018, 10:22 AM)kyllo Wrote: que instalé en mi rock64 emmc de android siguiendo este tutorial http://files.pine64.org/doc/rock64/guide...o_eMMC.pdf y todo bien, pero cuando comienza en unos segundos, se queda atascado.
¿Sabes que puedes ser? Gracias.
¿Qué mensaje de error recibe si sabe que está bloqueado?
no aparece ningún mensaje de error, simplemente se bloquea, no puede navegar por los menús y en algún momento se ha bloqueado cuando aparece en la pantalla de Android, simplemente comience.
Sugerencia, mantenelo en ingles en este foro, por ahora voy a traducirtelo de manera cruda para ver si te ayudan.
Im suggesting him to keep it in english in this forum and also offered to crudelly translate it to english basically he said this:
there is no error message, it simple freezes, cant open any menus and once it even froze on the android screen (i guess he refer to the logo screen) as soon as it starts...
Now my own little tip, did you write the image with etcher? if so did you had enabled the verification part? the psu (ac adapter) is a good one? are you sure it works fine and stable?
I'm sorry, I did not realize that I put it in Spanish, I'm not good at English and I use the Google translator.
I wrote the image as it comes in that manual, without problems, the ac adapter I bought it in the web of pine along with the plate, it must be good. I do not know what is the verification, I am very new to this and until now I only found that manual that is the one I followed.
Thank you very much.
android locked!! - by kyllo - 03-20-2018, 10:22 AM
RE: android locked!! - by evilbunny - 03-20-2018, 09:33 PM
RE: android locked!! - by kyllo - 03-21-2018, 03:47 AM
RE: android locked!! - by Trash_Can_Man - 03-22-2018, 04:25 PM
RE: android locked!! - by kyllo - 03-23-2018, 11:28 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,203 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,981 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,525 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,021 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,986 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,467 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,950 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,555 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,691 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,726 09-09-2020, 08:44 AM
Last Post: BowerR64
