LED Status Rock64
Controllable LEDs are red and white LEDs
The green LED is a power supply lamp, it lights up when power is supplied.
Lighting can not be controlled.
> flash when there is disk activity
I think that it refers to things such as "USB-HDD", but it can not be done at present.
You need to add code to realize the function to the kernel.
With the latest Ver dts (4.4.120)
    linux, default-trigger = "disk-activity"
It already has the above setting.
But, the 4.4.xx kernel does not support this keyword(""disk-activity").
It is supported keyword  at Main-line-kernel (Ver 4.16.xx, ..)
But, this keyword is for activity of "ata-disk".
For this reason, in the current rock64, setting "disk-activity" is meaningless for any kernel.
LED Status Rock64 - by Dayve - 03-13-2018, 03:30 PM
RE: LED Status Rock64 - by pfeerick - 04-18-2018, 09:21 PM
RE: LED Status Rock64 - by thewonderer - 04-19-2018, 12:28 AM
RE: LED Status Rock64 - by t4_4t - 04-19-2018, 03:07 AM
RE: LED Status Rock64 - by pfeerick - 04-19-2018, 05:25 AM
RE: LED Status Rock64 - by mr.travo - 05-09-2018, 08:05 PM
RE: LED Status Rock64 - by pfeerick - 05-10-2018, 04:38 AM
RE: LED Status Rock64 - by mr.travo - 05-10-2018, 01:42 PM
RE: LED Status Rock64 - by pfeerick - 05-10-2018, 07:44 PM
RE: LED Status Rock64 - by psychedup - 05-11-2018, 02:22 PM
RE: LED Status Rock64 - by pfeerick - 05-12-2018, 03:51 AM
  Are HW design files available for ROCK64? irenek 3 4,777 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,069 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 624 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,231 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,748 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,530 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,628 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,532 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,048 09-28-2021, 03:07 PM
Last Post: TRS-80
