Problems with USB 3.0 and SATA disk (UAS)
(10-16-2018, 09:59 AM)lupa18 Wrote:
(10-16-2018, 08:39 AM)Trash_Can_Man Wrote:
(10-14-2018, 09:10 AM)lupa18 Wrote: same here ! please help up
Holy necro batman, and afaik its a linux problem not specific to pine nor rockchip since armbian disables UAS on allmost all their SBC images (if not all), iirc the problem comes from the fact that manufacturers dont care to make hdd firmwares 100% compliant so linux either goes a hackish way to make it work or simply disable it...so basically yea, it needs to be fixed but you cant blame pine specifically for this issue...
Where can I report ?
Im not expert in the subject by any means but i can use google same as you, "apparently" (not completelly sure) you should report here, there are even 2 more reports there about uas problems so im probably barking at the right tree...
Scratch that, i found that they dont use bugzilla, you need to send a mail to a mail list, the direction is here.
RE: Problems with USB 3.0 and SATA disk (UAS) - by Trash_Can_Man - 10-16-2018, 11:05 AM
  Full Disk Encryption archangel 3 4,484 03-30-2019, 11:13 AM
Last Post: gzom
  Gigabit Ethernet problems aaronw 2 5,984 02-16-2019, 03:04 AM
Last Post: uttam
  USB3 problems scalextrix 2 3,976 09-08-2018, 01:15 AM
Last Post: scalextrix
  Xenial Mate: Screensaver Preview & LibreOffice Slideshow problems moravecz 2 3,310 08-27-2017, 10:37 PM
Last Post: moravecz
