SD Card (W10 IoT)
Hello folks,
I've been playing with my A64+ for the last few days.... for some reason, whenever I leave my A64 "alone" for a few hours, it reboots (this is just an educated guess) and enters some kind of maintenance mode: if I connect it to a monitor, it shows the "usual" spinning gears. However, it never gets out of it (or at least, it doesn't in 32 hours). Power cycling does not help - the next boot is always to spinning gears, unless (of course) I re-flash the SD-Card.
I've tried 3 times with two different cards - same thing. Examining the SD, I've seen that in fact widows did resize the data partition to reclaim the unused space at the end of the card. Tonight I'm going to give it another spin, but this time I've expanded the partition on my PC right after re-flashing the ffu. I'm using IoT Dashboard to do the flashing (in case it matters).
What I'd like to know is..... Is this an expected behavior? Did any of you experience the same thing?
SD Card (W10 IoT) - by zio69 - 03-08-2018, 04:30 AM
RE: SD Card (W10 IoT) - by zio69 - 03-08-2018, 11:59 PM
RE: SD Card (W10 IoT) - by chrmac72 - 03-16-2018, 12:41 PM
RE: SD Card (W10 IoT) - by KNERD - 07-19-2018, 10:43 PM
RE: SD Card (W10 IoT) - by tllim - 07-22-2018, 07:12 AM
Tongue Windows iot 10 SD card:) 7emey 0 5,387 11-28-2016, 10:53 AM
Last Post: 7emey
