New github source for rtl8812au !
Newer gcc compiler may fail to build the rtl8812au package found at
https://github.com/gnab/rtl8812au.git
as mentioned on the forum
A corrected version can be found at
https://github.com/abperiasamy/rtl8812AU_8821AU_linux
The simple procedure is still
git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux
cd rtl8812AU_8821AU_linux
ARCH=arm64 make
sudo ARCH=arm64 make install
If you have dkms installed
sudo ARCH=arm64 make -f Makefile.dkms install
seems to work fine
New github source for rtl8812au ! - by pytheas - 03-06-2018, 09:56 AM
  RTL8812AU driver and connection issues pane 7 13,362 12-20-2018, 04:56 PM
Last Post: pane
  Rock64 RTL8812AU dongle (from store) how to get working on Android? Nelly 4 8,791 02-07-2018, 10:28 PM
Last Post: varos16
