Power Via usb
Hi another question I want to be able to power my rock64 by usb so I can plug direct into USB power supply. Will this adapter from store work or is there more to it? Also will 5v 2.4a be sufficient enough to power the rock64? Thanks.
https://www.pine64.org/?product=2-meters...ower-cable
Power Via usb - by Nelly - 02-23-2018, 02:45 PM
RE: Power Via usb - by Luke - 02-23-2018, 03:08 PM
RE: Power Via usb - by Nelly - 02-24-2018, 01:51 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,357 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,321 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 7,763 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 2,390 09-06-2022, 02:46 AM
Last Post: ju0n
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 5,609 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 3,944 06-23-2019, 05:01 PM
Last Post: Rocklobster
  USB3 enough to power 2,5 external HDD? va88 11 19,771 06-06-2019, 03:40 PM
Last Post: va88
  How to check if my power supply is underperforming? va88 3 6,442 06-02-2019, 05:59 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 8,563 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 4,118 11-26-2018, 11:45 PM
Last Post: evilbunny
