(02-23-2018, 12:53 PM)dkryder Wrote: if touch is controlled by usb then you should have a config file to set the location.
Could you provide a bit more details?
I have simply plugged it and it worked without the need to install anything.
How could this file be named?
When I connect the device, I can see in dmesg, that it is detected and it uses the
hid-multitouch input,hiddev0,hidraw3: USB HID v2.00 Mouse [Touch Device ....] on usb-ff5d0000.usb-1/input0
still I am not sure where I could modify the settings.
I've found
https://www.chalk-elec.com/?p=2028
will give it a try, sounds reasonable
