[Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64
(03-05-2018, 01:36 AM)jegb Wrote:
(02-23-2018, 10:26 AM)xalius Wrote: I am pretty sure you can not build that module from mainline 4.13.x against a BSP kernel 4.4.77... as I said above, you have to cherry-pick the patches from linux-lima-4.13 and apply them to https://github.com/ayufan-rock64/linux-mainline-kernel/ ...
I am getting this on
$sudo make install:
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  CHK     include/generated/bounds.h
  CHK     include/generated/timeconst.h
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
make[1]: 'include/generated/vdso-offsets.h' is up to date.
  CHK     scripts/mod/devicetable-offsets.h
  CHK     include/generated/compile.h
  CHK     kernel/config_data.h
/bin/bash ./arch/arm64/boot/install.sh 4.4.114-gccfa68a3e270-dirty \
arch/arm64/boot/Image System.map "/boot"
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.114-gccfa68a3e270-dirty /boot/vmlinuz-4.4.114-gccfa68a3e270-dirty
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.114-gccfa68a3e270-dirty /boot/vmlinuz-4.4.114-gccfa68a3e270-dirty
update-initramfs: Generating /boot/initrd.img-4.4.114-gccfa68a3e270-dirty
WARNING: missing /lib/modules/4.4.114-gccfa68a3e270-dirty
Ensure all necessary drivers are built into the linux image!
depmod: ERROR: could not open directory /lib/modules/4.4.114-gccfa68a3e270-dirty: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
Warning: root device  does not exist
depmod: WARNING: could not open /var/tmp/mkinitramfs_AwXRHp/lib/modules/4.4.114-gccfa68a3e270-dirty/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_AwXRHp/lib/modules/4.4.114-gccfa68a3e270-dirty/modules.builtin: No such file or directory
Using DTB: rk3328-rock64.dtb
Couldn't find DTB rk3328-rock64.dtb in /usr/lib/linux-image-4.4.114-gccfa68a3e270-dirty or /etc/flash-kernel/dtbs
run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
arch/arm64/boot/Makefile:54: recipe for target 'install' failed
make[1]: *** [install] Error 1
arch/arm64/Makefile:119: recipe for target 'install' failed
make: *** [install] Error 2
Could you describe how to apply the patches for this lib?
Thank you for trying out various things.
By the way, what is a patch?
RE: [Progressed] [Successful] How to play Minecraft with ROCK 64 - by pine3228 - 03-05-2018, 03:30 AM
  Rock 64 failure / kernel panic n0021913 2 1,686 07-07-2022, 01:16 PM
Last Post: anchor00
  First-Timer trying to set up a minecraft server Sothe 3 4,619 05-31-2019, 02:59 PM
Last Post: Luke
  Rock 64 seem like a dead end munocat 3 4,870 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 2,961 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock 64 a failure..very disappointed arxaios 5 6,834 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 7,883 04-18-2018, 09:12 PM
Last Post: pfeerick
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,581 03-16-2018, 05:40 PM
Last Post: pine3228
Sad Rock 64 No video borisacomputers 4 5,456 03-03-2018, 03:11 PM
Last Post: borisacomputers
Wink My Stick of Rock digitaldaz 3 3,871 10-26-2017, 09:23 AM
Last Post: Luke
  Is the Rock 64 something strange? kometchtech 13 14,105 08-20-2017, 06:00 PM
Last Post: sjk
