[Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64
(02-19-2018, 08:55 AM)xalius Wrote: How did you change the .config exactly? Can you upload it to pastebin? Also upload the output of your kernel build...
Edit: I just saw that linux-lima is a mainline 4.13 source tree, so you better take the .config from ayufan's mainline kernel ( https://github.com/ayufan-rock64/linux-m..._defconfig), but 4.13.x is also too old for RK3328, the HDMI drivers you need for video output are probably arriving in 4.17.x or 4.18.x... so you need to forward port the linux-lima patches, from what I read in the issues in the git repo starting from " f0fddeaf1b7df4f1f7404155ad8b03a5190e5550 : drm/lima: init commit for adding lima driver"
[url=https://github.com/yuq][/url]
When attempting to compile a DRM driver and a LIMA driver in "rock64", the following error occurred.
How can you solve it?
Please cooperate with me.
rock64@rock64:~/linux-lima-lima-4.13/drivers/gpu/drm$ sudo make -C
/lib/modules/4.4.77-rockchip-ayufan-136/build M=$PWD
CONFIG_ARCH_ROCKCHIP CONFIG_DRM
[sudo] password for rock64:
make: Entering directory '/usr/src/linux-headers-4.4.77-rockchip-ayufan-136'
make: *** No rule to make target 'CONFIG_ARCH_ROCKCHIP'.  Stop.
make: Leaving directory '/usr/src/linux-headers-4.4.77-rockchip-ayufan-136'
/lib/modules/4.4.77-rockchip-ayufan-136/build M=$PWD CONFIG_DRMmake:
make: *** No rule to make target 'CONFIG_DRM'.  Stop.
CONFIG_ARCH_ROCKCHIP=m CONFIG_DRM=m
  CC      /home/rock64/linux-lima-lima-4.13/drivers/gpu/drm/drm_crtc_helper.o
/home/rock64/linux-lima-lima-4.13/drivers/gpu/drm/drm_crtc_helper.c:39:10:
fatal error: drm/drm_encoder.h: No such file or directory
 #include <drm/drm_encoder.h>
compilation terminated.
scripts/Makefile.build:258: recipe for target
'/home/rock64/linux-lima-lima-4.13/drivers/gpu/drm/drm_crtc_helper.o'
failed
make[1]: *** [/home/rock64/linux-lima-lima-4.13/drivers/gpu/drm/drm_crtc_helper.o]
Error 1
Makefile:1424: recipe for target
'_module_/home/rock64/linux-lima-lima-4.13/drivers/gpu/drm' failed
make: *** [_module_/home/rock64/linux-lima-lima-4.13/drivers/gpu/drm] Error 2
RE: [Successful] How to play Minecraft with ROCK 64 - by pine3228 - 02-23-2018, 07:56 AM
  Rock 64 failure / kernel panic n0021913 2 1,633 07-07-2022, 01:16 PM
Last Post: anchor00
  First-Timer trying to set up a minecraft server Sothe 3 4,550 05-31-2019, 02:59 PM
Last Post: Luke
  Rock 64 seem like a dead end munocat 3 4,801 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 2,905 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock 64 a failure..very disappointed arxaios 5 6,721 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 7,758 04-18-2018, 09:12 PM
Last Post: pfeerick
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,556 03-16-2018, 05:40 PM
Last Post: pine3228
Sad Rock 64 No video borisacomputers 4 5,370 03-03-2018, 03:11 PM
Last Post: borisacomputers
Wink My Stick of Rock digitaldaz 3 3,819 10-26-2017, 09:23 AM
Last Post: Luke
  Is the Rock 64 something strange? kometchtech 13 13,784 08-20-2017, 06:00 PM
Last Post: sjk
