[Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64
(02-19-2018, 04:55 AM)xalius Wrote: Hi, to compile a kernel on the Rock64, check out this repo
git clone https://github.com/ayufan-rock64/linux-kernel
then
make rockchip_linux_defconfig
then
make menuconfig
add the options you need and
make -j5
after that you should have everything built... building on the Rock64 will take quite some time if you dont have a heatsink and the cores get throttled, it should be around 40 minutes with good cooling...
Are you sure limadriver is already in a state that can be used for what you want to do? As opposed to mali?
Mali-450で、OPENGLを実行するためにはどうしても「linux-lima」ドライバーを使う必要があります。
私は、
をした後、生成され「.config」ファイルを、「linux-lima」のディレクトリに上書きし、
make oldconfig
make -j5
をしましたが、なぜか一部のドライバーがコンパイルされませんでした。
それは、「-C」オプションをつけても無意味でした。
それと、その後、コンパイルされたカーネルは、どのようにインストールすればよいのでしょうか?
make install
を実行しても、エラーが出てしまいます。
何故?
Google Translate :
With Mali - 450, you absolutely need to use 'linux - lima' driver to run OPENGL.
I,
After doing, overwrite the generated ".config" file over the "linux-lima" directory,
make oldconfig
make - j 5
I did, but some drivers were not compiled for some reason.
It did not make sense to attach the "- C" option.
Also, how do you install the compiled kernel afterwards?
make install
Even if you execute, an error will appear.
why?
RE: [Successful] How to play Minecraft with ROCK 64 - by pine3228 - 02-19-2018, 05:17 AM
  Rock 64 failure / kernel panic n0021913 2 1,631 07-07-2022, 01:16 PM
Last Post: anchor00
  First-Timer trying to set up a minecraft server Sothe 3 4,547 05-31-2019, 02:59 PM
Last Post: Luke
  Rock 64 seem like a dead end munocat 3 4,798 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 2,905 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock 64 a failure..very disappointed arxaios 5 6,715 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 7,751 04-18-2018, 09:12 PM
Last Post: pfeerick
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,555 03-16-2018, 05:40 PM
Last Post: pine3228
Sad Rock 64 No video borisacomputers 4 5,365 03-03-2018, 03:11 PM
Last Post: borisacomputers
Wink My Stick of Rock digitaldaz 3 3,812 10-26-2017, 09:23 AM
Last Post: Luke
  Is the Rock 64 something strange? kometchtech 13 13,770 08-20-2017, 06:00 PM
Last Post: sjk
