Onboard IR receiver
Thanks a lot!
I failed multiple times using only the info you gave me and what I gathered from around the internet about device trees. Still, I learned that by using dtc to output the default dtb in dts format and using the latest debian stretch from ayufan (stretch-minimal-rock64-0.6.23-189-arm64.img), there actually is an ir-receiver:
       ir-receiver {
               compatible = "gpio-ir-receiver";
               pinctrl-0 = <0x8b>;
               pinctrl-names = "default";
               status = "okay";
So my question is - how do I add the missing node properties without using variables? I know hardcoding values is bad style, but I think this would be the easiest approach for me. In other words, how do I manually convert for example:
<&gpio2 RK_PA2 GPIO_ACTIVE_LOW>
Into a value like:
<0x8b>
My idea is to do that for all the missing/differing properties:
   gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_LOW>;
   linux,rc-map-name = "rc-pine64";
   pinctrl-0 = <&ir_int>;
And then to compile the patched dts into dtb and overwrite the current dtb.
I'm lost in the sources in your github, I obviously don't understand enough (or, well, anything) about device trees, etc. so I will once again be very thankful for any help and direction.
Onboard IR receiver - by plambe - 02-12-2018, 04:50 PM
RE: Onboard IR receiver - by plambe - 02-13-2018, 06:56 AM
RE: Onboard IR receiver - by Kwiboo - 02-13-2018, 01:01 PM
RE: Onboard IR receiver - by plambe - 03-01-2018, 04:28 AM
  Migrate Linux from microSD to onboard eMMC elik745i 7 9,864 11-03-2018, 08:23 AM
  Onboard LEDs connected to the RK805-1 out1 and out2 GPIO pins prof7bit 8 6,623 03-03-2018, 02:58 PM
Last Post: prof7bit
