snapd
I am trying to install NextCloud on my rock64 but i'm running into a problem.  NextCloud uses snapd to install its packages which is supposed to come with ubuntu 16.04 by default.  It does not appear to be installed on the rock64 xenial image version 0.5.15-136.  I tried installing it manually but it failed because it failed to mount the core.  The error was: "mount[31508]: mount: unknown filesystem type 'squashfs'".  I tried to do an internet search and it mentioned this can be an issue with custom linux kernals.  I wasn't able to find anything more helpful then that though in how to fix the issue.  Does anyone have any suggestions on how to fix this issue?  Also in case the forum manager sees this i might have made this thread on the wrong board earlier for the pine64.  If it did go through please remove it.
snapd - by c1derly - 02-11-2018, 01:48 PM
RE: snapd - by dkryder - 02-11-2018, 02:18 PM
RE: snapd - by xalius - 02-11-2018, 02:24 PM
snapd - by jsfrederick - 02-11-2018, 09:43 PM
RE: snapd - by c1derly - 02-14-2018, 11:29 AM
