I can't compile kernel !! part2
私は、タイムスタンプを修正することでコンパイルができましたが、
新たな問題が発生しました。
「make install」を実行しましたが、
/bin/bash ./arch/arm64/boot/install.sh 4.13.0 \
arch/arm64/boot/installsh 4.13.0\
run-parts: executing /etx/kernel/postinst.d/apt-auto-removal 4.13.0 /boot/vmlinuz-4.13.0
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.13.0 /boot/vmlinuz-4.13.0
update-initramfs: Ganerating /boot/iniitrd.img-4.13.0
Warning: root device  does not exist
Using DTB: rk3328-rock64.dtb
Couldn't find DTB rk3328-rock64.dtb in /usr/lib/linux-image-4.13.0 or /etc/flash-kernel/dtbs
run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
arch/arm64/boot/Makefile:40: recipe for target 'install' failed
make[1]: *** [install] Error 1
arch/arm64/Makefile:124: recipe for target 'install' failed
make: *** [install] Error 2
と表示されてしまいました。
どうすればよいのですか?
Google Translate :
I could compile by modifying the timestamp,
A new problem has occurred.
I run "make install"
And it was displayed.
What should I do?
I can't compile kernel !! part2 - by pine3228 - 02-05-2018, 01:47 AM
RE: I can't compile kernel !! part2 - by xalius - 02-05-2018, 03:52 AM
  Rock 64 failure / kernel panic n0021913 2 1,702 07-07-2022, 01:16 PM
Last Post: anchor00
  Rock64 kernel panics clay 15 11,662 10-17-2021, 06:30 PM
Last Post: Rocklobster
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 1,537 07-02-2021, 03:13 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 15,203 11-17-2020, 08:00 AM
Last Post: Johannes
  How to compile ayufan repo step by step? hisstone 0 1,821 03-12-2019, 03:09 AM
Last Post: hisstone
  Rock64 kernel compilation - configs acrobatbob 0 2,230 04-06-2018, 02:55 AM
Last Post: acrobatbob
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,589 03-16-2018, 05:40 PM
Last Post: pine3228
  booting a kernel over tftp hibernick 0 1,804 03-08-2018, 10:37 AM
Last Post: hibernick
  Error when building kernel - realtek krystian 1 2,289 02-25-2018, 03:58 AM
Last Post: krystian
Video Kernel Panic on Rock64 linux tanisou 15 17,722 09-09-2017, 04:48 PM
Last Post: rmbusy
