Im having weird crashes on a new rock64 [solved]
(02-04-2018, 01:51 PM)dkryder Wrote: "Process deluged" that is the deluge daemon. maybe try just running the image without any of the other stuff to see if it is stable alone. then add the hd and run a bit with just that [unless image is on hd of course] then add each package alone and test . adding another until you get crash. then remove last one added and see if once again stable.
I did that, up and down, left and right, different versions of distros (all around OMV), EVERYTHING you can imagine of from the point of view of an advanced user, on the end i decided that i needed to try removing OMV from the equation and magic, no more problems (the weird thing is, i even have more speed now without omv, i was getting about 65mb/s speed to/from the drive, now on a simple samba manual setup+deluge it has been stable for several hours and im getting about 90mb/s stable)...omv causes some conflict with my external hdd...anyway, im working on setting all up manually and trying without success to secure samba and connect from w7 (the previous tests where without security of any kind) but at least im runing stable now...another option is to use ftp or sftp, im not extremelly paranoid with security but a drive without a simple user/pass is calling for problems...
TLDR: apparently the "optimizations" that the OMV team use on their distros cause problems with my hdd
RE: Im having weird crashes on a new rock64 - by Trash_Can_Man - 02-04-2018, 03:03 PM
  Rock64 - not booting after Armbian update helpmerock 6 1,002 03-27-2025, 08:26 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 8 2,711 01-25-2025, 12:57 PM
  can rock64 4gb ram run entirely on free software? heocb 1 586 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 666 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 1,603 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 55,724 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 89,980 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 2,550 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 1,042 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 1,710 11-21-2023, 08:33 AM
Last Post: as365n4
