(01-28-2018, 05:24 AM)Chris66 Wrote: Hi evilbunny - Thanks for your suggestion,
I have already tried the script, which however gives a lot of message about missing program packages and not compatible packages.
Have also tested the other suggestions, regarding Debian desktop, in this forum, but nothing works on my Rock64 with 4GB of RAM, that I received on January 8th, 2018, from Pine64.
It should also be mentioned that bionic-minimal-rock64-0.6.15 -175-arm64. img. XZ works impeccable, with X11 and LXDE. The only problem I have with it is that there is the commercial company behind which I am not happy with.
Have you tried using the debian mate image?
Also about missing packages you can usually fix this by:
sudo apt-get update
