RockPro64 and Pine H64 Discussion Thread
#59
(04-29-2018, 08:49 AM)tllim Wrote: The antenna concern has been discussed once at CNX Software site. The ROCKPro64 Wifi/BT module is NOT on board antenna type which may subject to the USB 3.0 noise interference. The ROCKPro64 Wifi/BT module using u.fl and we supply two wire antennas, just makes sure that the Wire antenna not getting too close or wire parallel with USB 3.0 cable. If not conformable with the Wifi/BT module due too close to USB 3.0, then the other option is using the PCI-e Wifi card.
The next batch should be product run unless this batch burn-in test result call fro another pilot run.
There is NO wire modification on current board, this issue has been fixed without physical jumping a wire.
I wasn't aware that the BT/WiFi module had U.FL connectors for external antennas. Big grin here.  Big Grin  Thanks!
The project I want to use this for involves BT connections and compression.
And thanks for improving the board's spec by adding DDR4. And at no additional cost.
RE: RockPro64 and Pine H64 Discussion Thread - by Tigger - 04-29-2018, 10:50 AM
  Shipping Update and Stock Availability Thread Luke 92 162,837 11-25-2024, 12:48 AM
Last Post: P. Siera
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 252,419 06-04-2021, 09:43 AM
Last Post: Luke
  PinePhone Mobian CE shipping update thread Luke 59 128,048 04-25-2021, 12:57 PM
Last Post: Luke
  PinePhone KDE Community Edition shipping update thread. Luke 135 264,572 04-11-2021, 01:47 PM
Last Post: Luke
  Manjaro Community Edition Shipping thread Luke 122 222,452 01-28-2021, 07:30 PM
Last Post: Muad
  December Community News Discussion Luke 2 11,756 01-19-2021, 04:48 PM
Last Post: zer0sig
Information August/ September Pinebook Pro, PineTab and PinePhone shipping thread Luke 256 546,618 10-27-2020, 11:14 AM
Last Post: Luke
  New Pine Store is up! Luke 17 43,754 10-12-2020, 04:28 PM
Last Post: zer0sig
  Pine Tab Markdanni123 3 8,909 10-04-2020, 11:26 PM
Last Post: zer0sig
  September Pine phone sales ? bcnaz 5 13,271 09-26-2020, 01:36 AM
Last Post: bcnaz
