40 pin header
Yes sure, as long as the pin also has GPIOx_ name in the schematic, you can disable the special function via the devicetree and use them as GPIO. You also have to disable the device node of the block using the pins in some cases, like UART2 here...
40 pin header - by GaryLa - 01-03-2018, 11:15 AM
RE: 40 pin header - by GaryLa - 01-05-2018, 09:52 AM
RE: 40 pin header - by zehks - 01-05-2018, 07:37 PM
RE: 40 pin header - by GaryLa - 01-06-2018, 01:11 PM
RE: 40 pin header - by xalius - 01-07-2018, 06:57 AM
RE: 40 pin header - by GaryLa - 01-07-2018, 11:58 AM
  Popcorn Hour Transformer header pinout yar 0 1,435 11-14-2020, 01:46 PM
Last Post: yar
  Quick question about the SPDIF header theophile 2 3,158 09-29-2020, 06:13 PM
