HDMI Video Resolution
(04-03-2016, 08:46 AM)Keex Wrote: The keyword is "Overscan" (google it for your TV) and it is not something you usually fix in the operating system (meaning your archlinux) but on your TV. Look for screen settings like scaling, or aspect ratio settings and see what is available. Usually the TV should have an option that will work.
No need to change the resolution.
Fantastic, buried 4 levels deep in a menu were some options I've never seen before .. "Picture Size = Screen Fit" has done the trick !!
Thanks ever so much for the quick and excellent help  Smile
(04-03-2016, 09:17 AM)HeadShot Wrote: Agreed,  I had the same problem on one tv but not another.  I went into the menus and found where the tv could do things like, zoom, stretch, dot for dot, etc.  The fix was selecting dot for dot on mine.
Good luck
Fixed too !!
HDMI Video Resolution - by patmolloy - 04-03-2016, 08:31 AM
RE: HDMI Video Resolution - by Keex - 04-03-2016, 08:46 AM
RE: HDMI Video Resolution - by patmolloy - 04-03-2016, 09:32 AM
RE: HDMI Video Resolution - by MegaMech - 04-28-2016, 12:36 PM
RE: HDMI Video Resolution - by HeadShot - 04-03-2016, 09:17 AM
RE: HDMI Video Resolution - by Andrew2 - 04-03-2016, 09:21 AM
RE: HDMI Video Resolution - by polypagan - 05-05-2016, 06:44 PM
RE: HDMI Video Resolution - by tkaiser - 05-06-2016, 01:02 AM
RE: HDMI Video Resolution - by tllim - 05-06-2016, 11:23 AM
RE: HDMI Video Resolution - by wahdooyah - 05-24-2016, 11:54 AM
RE: HDMI Video Resolution - by jwouellette - 07-27-2016, 10:37 PM
  Video conferencing aproject oxoocoffee 1 3,046 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
  Pine HDMI -> DVI monitor Pineapple 4 7,799 09-10-2019, 11:28 AM
Last Post: Pineapple
  First Boot HDMI/USB problem reefer 1 5,008 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,183 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  HDMI "Format not supported" sam452 3 6,568 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 15,950 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI and LCD hienhuynh1982 19 25,180 03-23-2017, 10:16 PM
  HDMI-VGA adapter. Blank screen. trumad 10 17,904 03-05-2017, 03:17 AM
Last Post: pfeerick
  red led + cat5 lights but noshow on DHCP list, no video mckenna.tim 1 3,815 01-24-2017, 12:03 PM
Last Post: Luke
  SSH works, but no video SvdSinner 8 10,813 12-08-2016, 12:59 PM
Last Post: MarkHaysHarris777
