Root Android TV
(12-18-2017, 03:48 PM)totalgaara Wrote: Hi, i received my Rock64 and i installed Android TV, it's work very fine  but the google play, is unfairly empty because the "rock64" is not recognized by Google. My goal is to edit the build.prop to make it look like an Nvidia Shield TV so many applications will be available and the rock64 can be used to its full potential
But there is a problem, how can i root it, I was able to access the Recovery with ADB and my goal was to install the zip archive supersu but the SD card can not be found (the system is installed on the EMMC), likewise in Android TV, if I go in the storage options I can read "The SD card was ejected safely" while I did not ask to do this.
Do you have an idea to counter this problem?
(I already tried app like Kingroot, doesn't work at all)
Thank you
(12-19-2017, 07:32 AM)totalgaara Wrote: It's a solution bug not a good one (i see i post in the incorrect section, sorry).
I will use my Rock64 as a "Mediacenter" so i use a remote control so it's not designed for "phone" apps that's why i'm on Android TV.
I know there is a way to root, just have to find how to make SD detected in Android :|
the rock64 android build link i posted is a rooted build. it is not a ayufan root build meaning that i'm sure parts come from ayufan work but the build is put out by pine64. root checker will verify as root. update binary by supersu works without messing up the build. ok, after explaining twice, i'm done. if you can not get a proper rooted build set up, the problem is you, that is, you are doing something wrong. so, good luck, merry christmas && happy new year both america && china.
Root Android TV - by totalgaara - 12-18-2017, 03:48 PM
RE: Root Android TV - by dkryder - 12-18-2017, 06:53 PM
RE: Root Android TV - by totalgaara - 12-19-2017, 07:32 AM
RE: Root Android TV - by dkryder - 12-19-2017, 06:48 PM
RE: Root Android TV - by xalius - 12-19-2017, 09:46 AM
RE: Root Android TV - by totalgaara - 12-19-2017, 10:02 AM
RE: Root Android TV - by totalgaara - 12-21-2017, 02:51 PM
  Download IDB fail when trying to flash Android image cherkasoff 0 4,275 04-05-2020, 07:41 AM
Last Post: cherkasoff
  How to get UHD 4k working (with Android TV 7) Hotkey 7 8,475 09-18-2018, 09:39 AM
Last Post: Trash_Can_Man
  AOSP Build Steps Using github.com/ayufan-rock64/android-7.1 birender.s 15 20,340 05-09-2018, 01:20 AM
Last Post: burram
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,581 03-16-2018, 05:40 PM
Last Post: pine3228
  Some questions about r64 and ayufan android tv Synthetikz 1 2,727 03-13-2018, 03:28 PM
Last Post: Luke
  USB HDD and Android TV JeffsNetflixPassword 2 3,431 02-18-2018, 11:36 AM
Last Post: JeffsNetflixPassword
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 5,121 02-02-2018, 08:37 AM
Last Post: dannyboyw
