Rock64 crashes(or goes into suspend maybe)everytime system idles
(12-14-2017, 03:36 AM)dkryder Wrote: you could try options/developer options/stay awake. if your system is displaying "no signal" that is many times a message from the monitor itself which would indicate that the monitor is getting no hdmi/lcd signal from the board which further indicates that the system is no longer functional OR the board is no longer providing the signal to the monitor for some reason. so until you can determine what the issue is you need to find a way to keep your system awake, at least as far as your monitor is concerned.
try a google search on "android keep awake apps" and go with something you think will work after spending some time learning about the issue you have.
Thanks for the suggestion. If it’s not the Operating system that is causing the “no signal” issue what’s the next thing I should look into? Maybe trying a new power supply?
Sent from my iPhone using Tapatalk
Rock64 crashes(or goes into suspend maybe)everytime system idles - by Sauromayne - 12-14-2017, 02:22 PM
  [Article] QuickJS JavaScript Engine on a Real-Time Operating System (Ox64 + NuttX) lupyuen 0 1,772 02-17-2024, 07:24 PM
Last Post: lupyuen
  [Article] Nim on a Real-Time Operating System: Apache NuttX RTOS + Ox64 BL808 SBC lupyuen 2 2,482 01-05-2024, 12:27 AM
Last Post: lupyuen
  [Article] $8 RISC-V SBC on a Real-Time Operating System: Ox64 + NuttX lupyuen 0 1,551 12-17-2023, 02:27 AM
Last Post: lupyuen
  [Article] RISC-V Ox64 BL808 SBC: Starting Apache NuttX Real-Time Operating System lupyuen 2 2,655 11-11-2023, 10:09 PM
Last Post: lupyuen
  System Updates DeanOnDoberman 2 3,879 11-09-2021, 02:11 AM
Last Post: DeanOnDoberman
  Sleep on Rock64 Grecor9090 1 4,140 10-26-2020, 07:42 PM
Last Post: KNERD
Question Does the Rock64 single board computer (1, 2 or 4 GB ram) have a PCie slot? IP_Proxy 5 9,358 04-29-2019, 08:19 PM
  Shipping time on a Rock64 package to the US jhereg 14 26,525 10-17-2018, 11:36 AM
  rock64 hdd from usb3.0 baszek 4 9,789 09-29-2018, 08:41 PM
Last Post: suberimakuri
