Enable I2C, I2s, SPI in boot-config file?
It seems that the way things are, the devices are not enablet right away. However, they can be enabled via "dts overlays", essentially additional changes to the internal "device tree" structure.
See https://github.com/ayufan-rock64/linux-b...al-devices
There is an example there of enabling a network interface. I found that I could enable the i2c-0 bus (the one on pins P3 and P5) by the following command, run as root:
enable_dtoverlay i2c0 i2c@ff150000 okay
where the names such as "i2c@ff150000" are found in the device-tree-source file on the github repository:
https://github.com/ayufan-rock64/linux-k...k3328.dtsi
Now, note that a number of GPIOs are already in use for various other purposes (the SPI for exampe is used for an on-board memory chip) and might not be readily available.
To have this happen on startup, put it into /etc/rc.local
RE: Enable I2C, I2s, SPI in boot-config file? - by KnReLe - 07-16-2018, 07:44 AM
  Rock64 won't boot luminosity7 10 4,055 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 323 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,524 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,073 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,045 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  Rock64 enable 1-wire to read DS18B20 or Dallas temperature sensor Perry 2 3,082 02-12-2021, 08:02 PM
Last Post: Perry
  boot hdd usb3 philipe 1 2,637 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,551 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,525 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,641 09-26-2020, 05:14 PM
Last Post: simonsouth
