root running from usb connected ssd locks up system
I connected a msata SSD (Samsung EVO 850) mounted in a case with USB3 to lower USB Type A plug. Then I copied root & swap onto it and replaced initrd and modified uDev.txt to set root filesystem on SSD
The whole process is described in this threaqd https://forum.pine64.org/showthread.php?tid=1114
In theory works fine. But after some time my pine just freezes out of nowhere. Sometimes it runs for minutes some times hours but sooner or later it locks up which is just a situation which I cannot accept as it's designed to run openHAB.
Does anybody have any input what might cause this before I throw the pine a64 into trash and switch back to rasperry pi3 which can boot directly from USB connected msata. I already have built 2 of these configurations and they just run and run and run.
Would be great to get any help, because the pine is much more powerful especially because I have the 2 GB version then the pi3 but it gave me so much headache so far that I'm really close to sell it and never try it again. Pine A64 support from creators also just sucks.
root running from usb connected ssd locks up system - by marcelser - 11-17-2017, 04:50 PM
  OMV base on Debian jessie Root Problem ayamy 3 4,671 09-03-2017, 09:21 PM
  resize root partition to max available space SD card can provide bilylilyli 16 16,794 11-18-2016, 07:10 PM
Last Post: pfeerick
  After update - won't power up with HDMI connected UnixOutlaw 6 6,810 09-09-2016, 01:43 PM
Last Post: janeku
  root password shaozhai 4 5,380 08-25-2016, 12:55 PM
Last Post: jl_678
  how to use USB hard disk as /(root) hatahata 15 14,790 07-01-2016, 07:09 PM
Last Post: hatahata
  How to install modules into system? MicroDiery 6 6,052 05-27-2016, 06:44 PM
Last Post: JamesHarris
Sad How to resize the root partition in order to fully utilize the SD Card MicroDiery 5 6,082 05-24-2016, 05:48 AM
Last Post: Luke
  Debian root's password? rayivy 2 3,539 05-12-2016, 08:59 PM
Last Post: rayivy
  what is the root password for debian? piahoo 5 9,669 04-29-2016, 02:12 PM
Last Post: rhkean
