rkflashtool -n does not recognize memory [RESOLVED]
@toby
Do you have any luck with this? I just get my Rock64 today.  I  have the same issue as your. I am using Linux Mint 18.3. The eMMC is a 16GB eMMC brought from PINE64. I tried various ways to described in the posts above. But the "rkflashtool n" output is always the same, like below:
rkflashtool: info: rkflashtool v5.2
rkflashtool: info: Detected RK3328...
rkflashtool: info: interface claimed
rkflashtool: info: MASK ROM MODE
rkflashtool: info: Flash ID: 00 00 00 00 00
rkflashtool: info: Flash Info:
    Manufacturer: Samsung (0)
    Flash Size: 0MB
    Block Size: 0KB
    Page Size: 0KB
    ECC Bits: 0
    Access Time: 0
    Flash CS:
Even if I doesn't plug in eMMC and SD, the "rkflashtool n" output is still the same.  Sad
RE: rkflashtool -n does not recognize memory - by yhlam - 12-18-2017, 10:19 AM
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 1,499 07-02-2021, 03:13 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 14,976 11-17-2020, 08:00 AM
Last Post: Johannes
Photo ROCK64 v3 4GB DDR board memory chip number Johannes 2 4,257 04-05-2020, 04:29 AM
Last Post: Johannes
  Rock64 does not boot - SPI problem [resolved] csharpy 7 10,340 03-21-2018, 09:34 PM
Last Post: pfeerick
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 5,055 02-02-2018, 08:37 AM
Last Post: dannyboyw
  ROCK64 does not recognize USB Wifi module (WL300NU-G) pine3228 2 4,067 01-03-2018, 03:56 AM
Last Post: pine3228
