rkflashtool -n does not recognize memory [RESOLVED]
If there are threads on this topic, please let me know and I'll close this one.
I am trying to verify that the storage modules are at least recognized by the Rock62 board ( v2.0, 2017-0713).
I'm following the steps outlined here:
* http://files.pine64.org/doc/rock64/guide...o_eMMC.pdf
https://github.com/fire219/sadie/blob/ma...x/sadie.sh
When I run the command `rkflashtool n`, it seems the board does not recognize the memory.  I've tried four different memory modules
  • 32 GB eMMC sold by pine64 ( two different individual modules )
  • 16 GB eMMC previously successfully running linux in a odroid C2
  • 1GB microSD ( could not verify still good )
In each case, the output is as follows.
sudo rkflashtool n
rkflashtool: info: rkflashtool v5.2
rkflashtool: info: Detected RK3328...
rkflashtool: info: interface claimed
rkflashtool: info: MASK ROM MODE
libusb: warning [darwin_transfer_status] transfer error: device not responding (value = 0xe00002ed)
libusb: error [submit_bulk_transfer] bulk transfer failed (dir = Out): pipe is stalled (code = 0xe000404f)
libusb: error [submit_bulk_transfer] bulk transfer failed (dir = In): pipe is stalled (code = 0xe000404f)
rkflashtool: info: Flash ID: 00 00 00 00 00
rkflashtool: info: Flash Info:
    Manufacturer: Samsung (0)
    Flash Size: 0MB
    Block Size: 0KB
    Page Size: 0KB
    ECC Bits: 0
    Access Time: 0
    Flash CS:
I would like to think this is an issue with MacOSx.  I do not have any of the accessories ( serial console adapter, USB->eMMC Adaptor ), but I would expect at least one of the chips to be recognized....
ProductName:    Mac OS X
ProductVersion:    10.12.6
BuildVersion:    16G1033
Procedure that I've been following:
  1. Set memory module
  2. Try to set the jumper ( different combinations )
  3. Insert power cable
  4. Remove jumper
  5. Insert USB cable
  6. Hold Reset button
  7. Hold Recovery button
  8. Release Reset button
  9. Release Recovery button after 2-5 seconds ( I've experimented )
  10. Run `rkflashtoon n` in console
Solid Red,Blueish,....Green lights.  No smoke.
Yeah, so, if you've gone down this path and found a solution, please let me know. Smile
rkflashtool -n does not recognize memory [RESOLVED] - by toby - 11-11-2017, 10:00 PM
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 1,531 07-02-2021, 03:13 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 15,160 11-17-2020, 08:00 AM
Last Post: Johannes
Photo ROCK64 v3 4GB DDR board memory chip number Johannes 2 4,318 04-05-2020, 04:29 AM
Last Post: Johannes
  Rock64 does not boot - SPI problem [resolved] csharpy 7 10,488 03-21-2018, 09:34 PM
Last Post: pfeerick
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 5,122 02-02-2018, 08:37 AM
Last Post: dannyboyw
  ROCK64 does not recognize USB Wifi module (WL300NU-G) pine3228 2 4,122 01-03-2018, 03:56 AM
Last Post: pine3228
