First Attempt: No Boot
(10-25-2017, 03:30 PM)Luke Wrote:
(10-25-2017, 09:12 AM)odatkid Wrote:
(10-24-2017, 04:55 PM)dkryder Wrote: it will probably be a good idea to use the battery and a power supply for a while until the battery becomes fully charged.
Thank you for the reply.
  I didn't have the battery in yet; just plugged in the power supply. Huh
Any other ideas?
Thank you.....Tom
Tom,
Which image did you download exactly using the installer utility ? did you connect the LCD correctly ?
This is one of those things that is easiest to troubleshoot in the IRC - so do join and try to get hold of me or someone else.
First Attempt: No Boot - by odatkid - 10-24-2017, 03:51 PM
RE: First Attempt: No Boot - by dkryder - 10-24-2017, 04:55 PM
RE: First Attempt: No Boot - by odatkid - 10-25-2017, 09:12 AM
RE: First Attempt: No Boot - by Luke - 10-25-2017, 03:30 PM
RE: First Attempt: No Boot - by odatkid - 10-26-2017, 03:38 PM
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,128 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,567 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,548 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,686 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,043 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,215 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,135 10-18-2020, 01:41 PM
Last Post: toiny
  Registration denied on first attempt - 29 seconds! andreasgoebel72 2 4,240 06-21-2020, 12:16 PM
Last Post: andreasgoebel72
  SD Card boot - trying out OS Baconomics 1 4,359 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,445 03-18-2020, 09:42 AM
