Cant make WiFi working on ROCK64.
Hi People!
I have 2 usb dongles for WiFi, but none of them are working in Rock64.
First one is a TP-Link WN721N uses AR9271 chip and is not accepted.
The second is a DLink DWA-123 uses RTL8188EU driver and is not accepted.
I think this is the same used in the dongle sold originaly by Pine site.
I running a Rock64 board with 2 Rb of Ram.
S.O. = MATE 1.12.1
Release 16.04.3 LTS (Xenial Xerus) 64-bit
Kernel Linux 4.4.77-rockchip-ayufan-136 aarch64
Running ifconfig only lo and eth0 are shown.
Running iwconfig only lo and eth0 are shown.
With tplink atached:
rock64@rock64:~$ lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
rock64@rock64:~$
With D-Link atached to USB 2.0:
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 003: ID 2001:3310 D-Link Corp.
My system is updated.
rock64@rock64:~$ sudo apt update
[sudo] password for rock64:
Hit:1 http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu xenial InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports xenial InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports xenial-security InRelease [102 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports xenial-updates InRelease [102 kB]
Get:5 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1,245 B]
Fetched 206 kB in 3s (52.3 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
rock64@rock64:~$
dmesg for DLink:
[ 2356.031492] usb 1-1: new high-speed USB device number 3 using dwc2
[ 2356.494490] usb 1-1: New USB device found, idVendor=2001, idProduct=3310
[ 2356.494522] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2356.494543] usb 1-1: Product: DWA-123 11n Adapter
[ 2356.494563] usb 1-1: Manufacturer: Realtek
[ 2356.494582] usb 1-1: SerialNumber: C0A0BB58700D
More information:
zgrep -i rtl /proc/config.gz
CONFIG_BT_RTL=y
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
# CONFIG_RTL8180 is not set
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=y
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
CONFIG_RTL8XXXU_UNTESTED=y
# CONFIG_RTL_WIRELESS_SOLUTION is not set
CONFIG_RTL8188EU=m
CONFIG_RTL8188FU=m
# CONFIG_RTL8189ES is not set
# CONFIG_RTL8189FS is not set
# CONFIG_RTL8723BS is not set
# CONFIG_RTL8723CS is not set
# CONFIG_RTL8723DS is not set
# CONFIG_RTL8822BE is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
# CONFIG_RTL8192U is not set
# CONFIG_RTLLIB is not set
rock64@rock64:~$
modprobe rtl8188eu
modprobe: FATAL: Module rtl8188eu not found in directory /lib/modules/4.4.77-rockchip-ayufan-136
Well, what can I do for WiFi to work???
Download something, compile something???
Thanks in advance,
VieiraBrazil
Cant make WiFi working on ROCK64. - by vieirabrazil - 10-21-2017, 11:45 PM
  DeskPi case alternative for ROCK64 v1k699 2 11,683 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,521 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,712 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 44,394 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 9,820 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,059 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 19,427 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 5,524 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 7,879 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 6,881 06-08-2022, 12:44 AM
Last Post: Zoz
