rock64 opencl version
(10-30-2017, 03:57 AM)nocrash Wrote: Mali4xx has no capability of OpenCL.
You have yo use Mali6xx series at least.
Not true, just have to use the standalone neon...
https://community.arm.com/graphics/b/blo...eon-driver
[Edit]
Things are not currently right with the graphics side and neon and the mainline status matrix has been updated with more support for 4.14.
I think there will be a flurry of work with that kernel and some new images to check.
There might be working software but so far I haven't really seen, something that I could call 'work as expected'.
You should be able to start X11 with OpenGL & Glamor acceleration (software) which I think runs in a similar way and has Neon support.
Crashes out with a seg fault and a bit past my limitations.
I haven't seen a working setup for either but haven't looked much at the OpenCL stuff.
Currently I don't think we are utilizing the Neon at all, we don't have a Midgard GPU, but it is better than the current CPU based offering we are using.
rock64 opencl version - by decebal - 10-21-2017, 02:20 PM
RE: rock64 opencl version - by stuartiannaylor - 10-21-2017, 02:45 PM
RE: rock64 opencl version - by nocrash - 10-30-2017, 03:57 AM
RE: rock64 opencl version - by stuartiannaylor - 10-30-2017, 05:57 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,360 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,381 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,443 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,349 12-07-2022, 08:22 PM
Last Post: luminosity7
