gpio driver porting from an r-pi3b
Hey Gene,
Sorry to hear about your wife's COPD. It's a hell of a challenge. I wish you both well.
Unless something changed on the Rock64, it uses the RK3328.
I am confused about your 7i92 speed concern. It's 100BaseT Ethernet and you can switch it so you avoid exclusive use of the Rock64's Ethernet port. I've used the 7i92 on x86 NUC-type solution.
For guidance on building Rock64 images I look to https://github.com/ayufan-rock64
Ever onward, Joe
gpio driver porting from an r-pi3b - by gene83 - 10-12-2017, 08:12 PM
RE: gpio driver porting from an r-pi3b - by joseph - 12-01-2017, 05:07 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,161 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 7,593 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 2,161 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 4,917 10-30-2020, 07:44 AM
Last Post: maks.dav
  RTL8812AU driver and connection issues pane 7 9,328 12-20-2018, 04:56 PM
Last Post: pane
  WIFI driver compilation wsk 1 2,837 11-01-2018, 12:21 AM
Last Post: wsk
  GPIO extension cable fault viguzzz 12 13,311 05-18-2018, 04:03 AM
Last Post: viguzzz
Question Rock64 GPIO Nak64Rbit 5 7,540 04-04-2018, 12:53 AM
Last Post: hryst
