gpio driver porting from an r-pi3b
(10-13-2017, 09:22 AM)gene83 Wrote: got it Mark, thank you. I might be back for clarification.
Never got away in fact. the setup.py didn't work And spit out pages of error/warnings. Hopefully what it did do is undoable. I'd post it, but its long and this software mucks up the formatting, and my ban on posting attachments hasn't expired.
Is this not available in the std "patch -p1 <patchfile" format so I can patch the 4.11.12-rt15 kernel src tree and rebuild?
Thanks Mark.
Cheers, gene83
If setup.py didn't work, the following should fix the errors.
For python 2.x
sudo apt-get install python-dev
For python 3.x
sudo apt-get install python3-dev
gpio driver porting from an r-pi3b - by gene83 - 10-12-2017, 08:12 PM
RE: gpio driver porting from an r-pi3b - by stacywebb - 10-19-2017, 11:23 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,188 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 7,612 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 2,164 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 4,954 10-30-2020, 07:44 AM
Last Post: maks.dav
  RTL8812AU driver and connection issues pane 7 9,356 12-20-2018, 04:56 PM
Last Post: pane
  WIFI driver compilation wsk 1 2,843 11-01-2018, 12:21 AM
Last Post: wsk
  GPIO extension cable fault viguzzz 12 13,351 05-18-2018, 04:03 AM
Last Post: viguzzz
Question Rock64 GPIO Nak64Rbit 5 7,552 04-04-2018, 12:53 AM
Last Post: hryst
