pine64 failed after 6 months
(10-10-2017, 06:36 PM)MarkHaysHarris777 Wrote:
(10-10-2017, 06:12 PM)sjk Wrote:
(10-10-2017, 06:07 PM)MarkHaysHarris777 Wrote:
(10-10-2017, 11:54 AM)sjk Wrote: Did the board go belly up?
Thanks,
Scott.
What do you think ?
... I would try the latest image ( not pre release ) from ayufan (gnu+linux).  Please use a Samsung Class 10 32G Evo Plus card.   Power the board via the euler bus  pin(6  -ground)  pin(4  +5v).   5v @2.5A   2500ma.
Save the boot log from the serial console.
Sometimes boards go bad;  happens.  Mine have run constantly for one year now;  however, I have heatsinks on the chip-set and I have a 5v controlled brushless fan over the SoC.
I have attached the boot log, is it not showing?
Sent from my XT1575 using Tapatalk
I want to see the boot log from the setup I described;  Samsung evo plus 32G card, powered via euler bus, running LINUX ...  latest release (ayufan, not pre release)...
I will try the latest release tommorow. I am using a 64gb Samsung (official) card.
As per the power supply, powering from the Euler bus is an option for a box on a bench. For me I need to move the unit around an run demos of streaming apps on it. I am using my rock64 for the moment.
I will order a new power adapter I can try on the Euler bus, but for me I would have to drill my machined aluminum case and add a barrel connector to make that work long term.
Sent from my Nexus 9 using Tapatalk
pine64 failed after 6 months - by sjk - 10-10-2017, 11:54 AM
RE: pine64 failed after 6 months - by sjk - 10-10-2017, 06:12 PM
RE: pine64 failed after 6 months - by sjk - 10-10-2017, 07:49 PM
RE: pine64 failed after 6 months - by sjk - 10-10-2017, 08:57 PM
RE: pine64 failed after 6 months - by sjk - 10-11-2017, 10:18 AM
Question External storage problem for pine64 Dani6102 4 1,734 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,296 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,163 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,835 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,134 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,786 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,967 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,843 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,602 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,279 05-03-2019, 02:48 PM
Last Post: Mendota
