Bluetooth CSR8510 not working with Rock64 Android 7.1
(10-07-2018, 10:14 PM)ls1115 Wrote:
(10-06-2017, 01:47 PM)efreeze Wrote: Hello Guys,
I have the Rock64 with the last version of Android installed on it. All is good excepted that my CSR8510 BT dongle is not working. I tried everything i can see on my rasperry pie with no issue but not on Rock64.
Anybody has any BT working on this platform on Android ?
Seb
I bought the bluetooth air mouse/keyboard unit sold by Pine. It works on my board with Android 7.1, except that I cannot turn the Rock64 on from the remote. After I turn on the unit manually, everything works well, including shutdown. I expected the faulty Bluetooth issue to be solved with Oreo, but looks like it got worse!
https://www.pine64.org/?product=pine64-a...h-keyboard
Is that one bluetooth tho? i had 3 different air mouse remote controls (not this one) on my hands and none of them where bluetooth, they use a proprietary transparent protocol to communicate with the usb adapter, basically from the point of view of the sbc you are pluggin a normal cabled keyboard and mouse...some backup information:
https://www.quora.com/Which-wireless-com...s-and-mice
http://www.cypress.com/file/104816/download
Apparently most of them work on the 2,4ghz frequency so interference can occur but they are not bluetooth afaik...
RE: Bluetooth CSR8510 not working with Rock64 Android 7.1 - by Trash_Can_Man - 10-08-2018, 05:04 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,212 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,991 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,529 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,100 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,992 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,468 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,954 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,557 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,695 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,738 09-09-2020, 08:44 AM
Last Post: BowerR64
