Compatible LCD DSI
#20
(01-11-2018, 03:15 AM)desai_amogh Wrote:
(01-11-2018, 02:11 AM)drock Wrote: I do not see how to buy the tp converter board though.
As it says, (This board needs to be built with connectors).  So you will have to get the PCB fabricated, buy connectors, solder them, etc.
Or have a company like Elecrow or allpcb build it for you.  Just send them the design file gerbers and they build it for you.
To make it more simple, Just send this file to elecrow at PCB@elecrow.com with these two parts No.
P4 and  P2 - Digikey part - https://www.digikey.com/product-detail/e...ND/5170911
P1 and P3 - Digikey part - https://www.digikey.com/product-detail/e...ND/5967755
They will make the PCB and assemble it for you. I expect the price to be less than $5 a board.  Minimum is 10 boards.
Compatible LCD DSI - by drock - 10-02-2017, 10:42 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 12:44 AM
RE: Compatible LCD DSI - by drock - 10-03-2017, 12:00 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 08:35 PM
RE: Compatible LCD DSI - by drock - 10-05-2017, 09:49 PM
RE: Compatible LCD DSI - by dkryder - 10-06-2017, 05:05 AM
RE: Compatible LCD DSI - by tllim - 10-11-2017, 01:02 AM
RE: Compatible LCD DSI - by desai_amogh - 12-12-2017, 02:42 AM
RE: Compatible LCD DSI - by drock - 12-20-2017, 03:51 AM
RE: Compatible LCD DSI - by tllim - 12-21-2017, 12:39 PM
RE: Compatible LCD DSI - by ricoli - 12-25-2017, 11:25 AM
RE: Compatible LCD DSI - by tllim - 12-25-2017, 03:34 PM
RE: Compatible LCD DSI - by drock - 12-26-2017, 02:23 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 04:15 AM
RE: Compatible LCD DSI - by tllim - 01-09-2018, 08:05 PM
RE: Compatible LCD DSI - by drock - 01-11-2018, 02:11 AM
RE: Compatible LCD DSI - by dkryder - 01-09-2018, 07:08 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 10:40 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 03:15 AM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 04:53 AM
RE: Compatible LCD DSI - by drock - 01-11-2018, 08:01 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 11:43 PM
  Search Compatible 10.1" touchscreen alfredo78 0 3,518 07-06-2018, 03:48 AM
Last Post: alfredo78
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,650 01-26-2017, 10:07 AM
Last Post: mbt28
