Lakka test boot-up Rock64.arm-8.1.2 dmesg logfile
(10-10-2017, 02:43 PM)Kwiboo Wrote: RetroArch will probably autostart if you remove textmode (or replace it with quiet) in extlinux/extlinux.conf on the boot partition
Yes. Still its weird that the assets don't load ... I experienced this in the past putting together a dedicated Retroarch build for the Pine64 - I remember that it was a permissions issue. Didn't have time to look into this - but I think the nature of the issue is different as the Lakka build runs as root.
RE: Lakka test boot-up Rock64.arm-8.1.2 dmesg logfile - by Luke - 10-10-2017, 02:57 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 136 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,330 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 324 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 596 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 597 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,264 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,565 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 583 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 636 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 614 03-03-2023, 09:24 PM
Last Post: acwest
