openHAB Packaging for the Pine64
(08-01-2016, 01:47 PM)tllim Wrote:
(07-31-2016, 12:15 AM)ewickham Wrote: I was supposed to get a SD card with OpenHAB pre-installed, but got an Android release instead. I'm comfortable with installing a base OS, then Docker and then using an OpenHAB container. I just want to make sure I get the right base image, since my current network layout is wireless - so I can't really use a headless image. Do I just grab the Debian image in the downloads section, and then add Docker? I have an Ubuntu (Mate GUI) - can I use that or are the libraries too different?
Or should I just request the pre-installed OpenHAB SD?
Sorry on teh shipping facility ship you the SD card with Android release. For OpenHAB build, you can download from http://wiki.pine64.org/index.php/Pine_A6...AB_Release and dd to the microSD card.
I'm still a little uncertain about what to expect once I download the image to the SD card and reboot the Pine64. Will I see a console login via HDMI? Maybe on an LCD display via the DSI connector? As I mentioned previously, my current work area for the Pine64 forces me to use wireless - and since mine is secured, I have to provide  authentication at some point. Will I need to use a wired ethernet connection first in order to configure the wireless? I presume once connectivity is configured I can ssh to the server, yes?
openHAB Packaging for the Pine64 - by kai - 03-31-2016, 02:17 PM
RE: openHAB Packaging for the Pine64 - by sja - 05-19-2016, 07:08 AM
RE: openHAB Packaging for the Pine64 - by kai - 05-23-2016, 12:43 AM
RE: openHAB Packaging for the Pine64 - by batrad - 06-08-2016, 12:39 PM
RE: openHAB Packaging for the Pine64 - by tllim - 06-08-2016, 04:03 PM
RE: openHAB Packaging for the Pine64 - by tllim - 08-01-2016, 01:47 PM
RE: openHAB Packaging for the Pine64 - by ewickham - 08-01-2016, 02:42 PM
RE: openHAB Packaging for the Pine64 - by tllim - 08-02-2016, 04:06 PM
RE: openHAB Packaging for the Pine64 - by B34N - 08-06-2016, 01:20 PM
RE: openHAB Packaging for the Pine64 - by tllim - 08-07-2016, 02:42 PM
RE: openHAB Packaging for the Pine64 - by kai - 09-04-2016, 02:18 AM
RE: openHAB Packaging for the Pine64 - by tllim - 09-21-2016, 01:39 AM
RE: openHAB Packaging for the Pine64 - by BatoXan - 02-21-2017, 07:19 AM
  openHABian for pine64 available dmcwhinnie 5 15,412 12-20-2017, 10:38 PM
Last Post: pineadmin
  Pine A64 + OpenHAB + Sonoff-pow: Would it Work? Bob123456789 6 14,504 05-31-2017, 02:54 PM
Last Post: Bob123456789
  Show Hubpanel on pine64 display Beta 0 4,083 04-15-2017, 05:44 AM
Last Post: Beta
Tongue Pine64 with Openhab2 - Starting guide/accessories g_t_j 4 12,688 03-12-2017, 05:13 PM
Last Post: BatoXan
  Keeping Openhab current socken23 4 10,586 01-13-2017, 12:51 AM
Last Post: swinging
  Pine64 and Aeon labsZ-Stick tomekr 1 6,183 12-19-2016, 05:41 PM
Last Post: Trond
  Pine64 and MQTT Grootkonijntje 2 10,143 09-22-2016, 04:01 AM
Last Post: pfeerick
  OpenHAB And Zwave FrenchFrog 12 29,749 09-13-2016, 11:17 PM
Last Post: bonterra
  OpenHAB Up - Getting My Bearings - Questions doundounba 4 9,374 07-08-2016, 12:38 AM
Last Post: av1024
Information [solved] Openhab not starting socken23 10 19,513 06-21-2016, 12:50 PM
Last Post: Luke
