09-22-2017, 06:24 PM
(This post was last modified: 09-22-2017, 06:25 PM by MarkHaysHarris777.)
hi , typically there are at least two things going on; 1) a shell or program, and 2) a terminal or gui.
Normally what folks want is a bash shell to run in a terminal ( notice the two things there , the shell and the terminal ). There are usually two options that one specifies in this case: 1) do you want the shell or program to run in a terminal, and 2) do you want to the terminal to close when the shell or program exits ?
So, you have two choices for Type: Application , or Application in Terminal.
Then you have the name: "Mate Terminal"
... then some comment like: Use the Command Line
and then you have the name of the executable: mate-terminal or /usr/bin/dash
For the Mate Terminal folks usually specify type "Application" , name "Mate Terminal" , command mate-terminal , and comment "Use the Command Line"
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697
( I regret that I am not able to respond to personal messages; let's meet on irc! )
