Won't power on/boot -- kickstarter A64 2GB
(09-22-2017, 02:09 PM)fuzzycuffs Wrote: Kickstarter backer, finally getting to playing with my A64+ 2gb
Using the new Etcher image burner on a Transcend 300x 16gb card UHS-1
No matter what image I use (Android, Linux, RemixOS, etc.), won't boot.
Power supply is a 5V 2.5A power supply I use with my Raspberry Pi 3 which works fine
Symptoms:
Red LED works/on when USB power is plugged in
HDMI out makes the monitor turn on, then off because 'no signal is detected', turns back on, turn off no signal -- keeps repeating
I'm unsure if this is power supply, memory card, or simply bunk A64 related.
Any help?
I have the same issue. Did you get this resolved?
RE: Won't power on/boot -- kickstarter A64 2GB - by GaryFunk - 04-15-2018, 11:13 PM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,605 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 3,934 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,973 02-23-2021, 05:33 PM
Last Post: thedu
  Pine64+ power button PaddyChan 0 2,786 09-14-2020, 09:55 AM
Last Post: PaddyChan
Exclamation Can't boot when SD card inserted kivox 5 8,056 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 3,717 11-29-2019, 04:39 AM
Last Post: evilbunny
  UK power supply (Pinebook Pro 64) skobi 0 2,306 11-17-2019, 04:55 AM
Last Post: skobi
  Pine A64 stuck in boot process joey 1 3,435 05-28-2019, 09:07 PM
Last Post: joey
  boot loop with lcd plugged in drock 0 2,041 01-09-2019, 01:37 AM
Last Post: drock
  LED flashes for 1 second, board won't boot Audioslave 2 4,144 08-02-2018, 10:28 PM
