The 6 most common reasons why Pine64 won't boot
(03-21-2017, 09:32 AM)Luke Wrote:
(03-20-2017, 07:05 PM)mitelheem Wrote: I'm pretty much at my wits end.. I can not get my pine to boot. I'm pretty sure it has something to do with the way I'm burning my SD card, but I can't figure out what that something is. I've tried two different pine boards, and I did get it to boot once, but only to HDMI. My goal is the LCD (and  I have an extra of those as well). my power supply is the Pine supplied ac adapter.
Ok. so I've tried dd and apple pi baker to both the SD card slot and USB slots on my mac, and also tried the Windows program. No joy. I've pulled off all the accessories from the pine (keyboard dongle, wi-fi) no joy. Since I'm not 100% certain my LCD panel is good, I'd like to be able to boot using the HDMI output first, and once I know its working, then mess with the LCD. My SD cards are all valid - name brands from reliable sellers. Anyone in Orlando area, or willing to mail me a working SD card?
mitelheem, seems like you've tried a few things already. Which img are you burning? - I presume Android with LCD support ? If you wan't to use Linux with the LCD you should first read this thread. Also, if you want to use Android 6 or 7 with the LCD make sure to read ayufan's instructions (see first thread of respective android version threads; e.g. android 6).
Are you getting activity on the ethernet port (did you read the short troubleshooting section in the wiki?)
Try joining in the IRC - these sort of things are easier to troubleshoot 'live'
Hi Luke,
Thanks for the advice. It's working now.. not sure what I did (or didn't) but both boards are working. I was using ayufan's instructions, and the Etcher software to burn it. I did find that one of my LCD panels is defective (a blue line running top to bottom about 1/3 way across) so I'll see if I can return that to Pine. I think my biggest problem was patience - I was expecting a more instant boot, and it seems that the pine likes to take its time. Now I just need to figure out how to get the touchscreen working, and then power it from 12v on my boat!!
RE: The 6 most common reasons why Pine64 won't boot - by mitelheem - 03-22-2017, 05:18 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 52 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,175 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,611 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,582 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,702 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,758 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,457 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,086 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,248 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,157 10-18-2020, 01:41 PM
Last Post: toiny
