Rock64 crash randomly during usb 3 copy with RAID1 drive
#22
(09-19-2017, 05:46 AM)rontant Wrote:
(09-19-2017, 02:26 AM)digitaldaz Wrote: Actually, how do you blacklist the UAS??
First, check if your USB enclosure is indeed a UAS enabled USB 3 enclosure. Use the command:
lsusb -t
Do you see your device listed as one using uas driver?
If yes, get the vendor ID and the product ID . Just use the command  line 'lsusb' without any parameter and you will see a list of USB devices with their respective ID numbers. Your USB enclosure should be one of them. If you use WD Passport 3TB, for example, you will see something like this:
Bus 005 Device 003: ID 1058:0827 Western Digital Technologies, Inc.
1058 is the vendor ID and 0827 the product ID.
Add these 2 numbers into the conf file in /etc/modprobe.d to blacklist the UAS
sudo nano /etc/modprobe.d/rk3328-usb-storage-quirks.conf
The ID numbers should be following the format 0xVendorID:0xProductID:u. Each blacklisted device should be separated by a comma. See the example below.
options usb-storage quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x0bc2:0xa013:u,0x1058:0x0827:u,0x0bc2:0x2101:u,0x2109:0x0715:u
Reboot twice.
Run 'dmesg' to verify.  If you edit correctly, you should see a line in dmesg saying your device has been blacklisted. If you run "lsusb -t" again,  it should say "driver=usb-storage"  instead of "driver=uas"
A BIG CAVEAT: Do this at your own risk.
Thanks @rontant, it works great
after your instructions, I also run "sudo update-initramfs -u"
root@rock64:~#sudo update-initramfs -u
reboot
root@rock64:~# dmesg | grep blacklisted
[    5.042432] usb 5-1: UAS is blacklisted for this device, using usb-storage instead
root@rock64:~#
RE: Rock64 crash randomly during usb 3 copy with RAID1 drive - by i69fstop - 05-08-2018, 01:52 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,361 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,384 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,519 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,361 12-07-2022, 08:22 PM
Last Post: luminosity7
